I have my engine out of the frame, does anyone have any recommendations about flushing the engine out? Any engine flush Products, or the best method of flushing?
i used kerosene, if you have the cam cover off you can just poor it right down the cam chain tunnel, leaving the drain plugs out. afterwards put some cheap oil into the engine cycle it over a few times by hand, drain the oil and refill with your preferred quality oil
Flushing only does a little bit. Many have flushed their engines 3-4 times and still don't get the little bits out. Why do you want to flush it? You can tell a lot from the oil and filters. Getting all those little bits of metal and/or plastic out is good, but what is causing it?
