On my XS650C (Type D Tensioner), I am experiencing the same type noise as Spitfire described at the beginning of this thread.
Yesterday, I removed my Cam Chain Tensioner (read it was easy to do, so what the hell). I've got a new O-ring (for large nut) and Gasket on order...
I've got the tensioner removed from my engine or at least the following: push rod(plunger), spring, 6-bolt mounting plate, copper damper washer, adjuster screw, and cam chain adjuster cap.
Perhaps a dumb question, but can any adjustments be made with the tensioner out of the engine? Assuming not, am I simply to re-assemble and reinstall the tensioner onto the engine and leave off the Adjuster cap, start the engine, and check for the plunger to be flush with the engine idling or at least with the engine warm?
Like comments I've read from 5Twins, I wonder what's to stop adjustments from going awry when tightening the adjuster cap in the absence of a lock nut on the Type D.
There's no problems with cranking the engine and idling with the large adjuster nut off?
I think I know what I need to do, but have some trepidation since I've never done this before.
Thanks!!
Some pics attached...
