alfredo
1978 xs650 Special
So, I am sure a couple of you have been thinking (or taken part in) about a rephase. I have decided, after all the questions and answers on this thread to jump in. My goal is to be able to have a smoother running cruiser. Something that will take me past my current 4.5k vibratory limit. I just want it to be smoother and more of a cruiser without taking too much money. I figured a build thread would be good to show my trials and tribulations. So here we go!
First of all, my motor is less than 2.5k miles since a top end rebuild and 3rd over bore. It has been leaking oil from all over. Have re-torqued and gooped yamabond 'till my hearts content and still my pants get oil all over them. Base gasket, head to valve cover, etc. Tiny leaks, but when you are traveling above 30mph, that oil gets everywhere! I am saying this, because even with no vibrations I would need to break this thing down to fix all those leaks.
Current Specs:
3rd Oversize
fresh top end
boyer ignition
bs38s
Goal Specs:
leave top end alone
delete base gasket
rephased crank/cam
PMA
Pamco
bs34s
Cleaner parts
Beginning:
Got the motor out, in the stand and on the table. Took some wrestling, but was able to yank it out and bear hug it up to the bench. I cut the new wiring to the rotor as I have plans for a PMA.
Some metal in the filter. I replaced both cam guides and I didn't see much black stuff. I didn't tear apart the bottom end when I rebuilt this so I am hoping that some of that metal is from the bottom end, previous internals. Hopefully that is Will know more as we get deeper into the puzzle though.
Got the side covers, clutch basket, kick starter, shift selector, starter bendix and oil pump drive gears all off. I broke a tooth off of the clutch basket while trying to remove it, reached out to the forum for some help and found one in trade from SimpleBob. Thanks again man! Other than that broken tooth, no major damage or missing metal in the gears, case, etc.
Valve cover off. Notice my gratuitous use of Yamabond Prob overkill as it looks like burnt pancakes inside there. Going to have to check and see if the cover is warped as this was a place where leaks were apparent. Not sure how to check for warps other than setting it on a table, but I guess I will learn. Also, springs and tappets all look great.
Cam, lobes and bearings all look great too. This piece will be shipping to Hugh soon. Hoping he works his voodoo for me.
The valves look charred, but seem ok. What does the forum think?
Pistons and sleeves look great too. The sleeves still have 99.9% of the machinist hatch marks in them so I am sure they have a long time to go. Won't be doing anything with these, just putting them back where they were when the rest of this motor is done.
Here is the base gasket. You can kind of see how it is lifted all the way around the sleeves. I can see where the oil just seeped out :/ Going to take Hughs advice and not run a base gasket to bump compression up more and hopefully no longer have an oil leak from this spot.
And here is how she sits now. Going to be trying to squeeze every minute in the afternoons into this thing so I can get it back together soon. I am thinking of replacing the main bolts as I fear some of them are stretched and might be one of the reasons that the seal was never as good as it could have been. Anyone have any input on swapping these? Worth it? Not worth it? Tips, etc?
More to come soon. Feel free to chime in.
Current Specs:
3rd Oversize
fresh top end
boyer ignition
bs38s
Goal Specs:
leave top end alone
delete base gasket
rephased crank/cam
PMA
Pamco
bs34s
Cleaner parts
Beginning:
