gggGary, those conrod mods were for the big end. All I could find on the little end was the cross drilling mod on MMM's site.
Looking at your piston & rod pics in your other thread, my first observations were about the severe scuffing on the front of the piston of the overheated rod. Looks like it may have experienced an overheat seizure there.
That front part of the piston and cylinder area is a punishment zone. During downstroke, the piston is slipping down a freshly oiled cylinder. During upstroke, the piston is moving over a freshly cleaned and scraped cylinder. Hopefully, sufficient oil is splashing thru the oiling holes just below the oil ring to lube the cylinder on this upstroke.
From BDC, to about halfway up, the piston is experiencing extreme acceleration, and the angularity of the conrod causes a forward thrust vector on the cylinder in that zone, up to several hundred pounds at high rpms, skyrocketing even higher at more rpms.
The shorter the conrod, the greater this angle, and the higher this 'sidewall thrust'.
As the piston/cylinder friction increases in this zone, the greater conrod force needed to overcome it, which increases the sidewall drag, requiring even more conrod push, and the whole thing just compounds from there.
That's why most blown engine post-mortems show severe piston-front wear, or cylinder fronts punched-out by the conrod.
Egads, am I rambling again...?
