OK put in a good battery. (the lithium wouldn't fit) same issue, weak spark. Cut out the ignition fuse holder, usual issue, crap fuse holders, ancient rotted fuse. Soldered in new fuse holder. Same issue, very weak spark, buzz effect after cranking , Hot wired from battery directly to iggy fuse, no change. Pulled TCI at plug, plugged in a tested good TCI,
Ta Da! GOOD STRONG spark. Put iggy back together, hooked up test fuel tank, one carb overflowed, shut off gas
then started it, vroom vroom, idled (very fast) AND revved. After few minutes turned gas back on, carb held without leaking, set idle stop screw to a reasonable position, it idled, ran, revved good, for bike with no air filters.... after a phone call to mr. flip, I pushed it out to the shed. He'll pick it up next week.
The mystery of the won't rev XS650
