Fork seals
yamageek
NY USA
If I am just changing fork seals is there really any reason to disassemble the forks? Neck bearings are done but wanted to change the seals as one seems to leak just a bit.
Well, you have to pull the lowers off to gain access to the seal. If just a slight leak, the seal may be fine. It may just have dirt in it and need to be cleaned. I'd try that first before replacement. I only replace a seal that needs it. On a couple of my bikes, I only replaced one fork seal because the other was still OK. Both those bikes have been like this for years now, one new fork seal, one old original, and they still work fine with no leaks.
It can be done. You have to remove the forks from the trees either way. Before you remove the forks loosen the fork cap. Need to loosen the upper tree bolts first or the cap won't come loose. Remove the cap. With forks fully extended fill with oil up to near the top of tube. Just room enough to replace cap.
Remove the fork from the trees. Slide the rubber boot on the top of the lower part of fork. Under that boot you will find a snap ring. Remove this ring and the spacer under it. You should be able to see the seal.
Now prop the fork some where like next to the deck of your house. The bottom of fork on something solid. With the top about even with the bottom of the deck. With a long 2x4 put one end of 2x4 under edge of deck. The 2x4 should run out across the top of fork. No lever the top of fork down with the 2x4, With enough pressure on the 2x4 the fork compresses enough to blow the seal up out of the fork.
Remove the fork cap, pour out oil. Replace the cap.
To replace the seal, slide the seal down the tube to top of the lower. Place the spacer on top of seal. Get a piece of PVC pipe big enough to slide down over fork tube. About the same outside diameter as the seal and spacer. The PVC pipe should be long enough so it stick up above the fork tube by a few inches. Now push down on PVC to press the seal into place. Might have to gently tap PVC with a mallet. If no mallet a piece of 2x4 will work. Just be gentle. Don't want to hurt the seal.
Once the seal is in place put the snap ring back to hold the seal. Put the boot back on.
At this point I would flush the forks with a suitable cleaner. Kerosene or fuel oil, Diesel even. Put in a cup or so. With the spring out. Collapse the fork and extend it to work the cleaner through the damper and other internal parts. Drain, Repeat till the cleaner comes out as clean as it went in.
Using oil flush the forks as described above. This removes the cleaner. Then refill with the amount of oil you choose. I like the 6 inches down method of filling the forks. With the fork collapsed, put in enough oil so the tp of the oil is 6 inches down from top of fork tube.
Easy way to do this is pour in about 8 to 10 ounces of oil. Extend and collapse fork a few times to work out the air. Take a piece of clear plastic hose, put a zip tie around the hose. Set it to 6 inches from one end. Slide this down into the fork till the zip ties is at the top of fork. I have a Miti Vac, I hook the Miti Vac to the hose and use it to draw out any oil above the end of the hose. This very precisely sets the oil level.
I have read about this method of seal replacement. It is very messy, Gets oil all over the place when the seal comes out.
You have the forks off the bike and half tore down any way, so why not tear them completely down and check the ingternal parts and clean them properly.
Just mostly a matter of having to make up a special tool to grab and hold the valve while removing bottom bolt. Not something that I have just laying around.
xsleo, thanks for that. I will read it for understanding later... A couple of years ago I got a local mechanic to do mine because I didn't want to bother, and he stripped both hex nuts going in the bottom! And seals not replaced....
OP, sometimes they will stop leaking by themselves if the grit has a chance to work out when you're in some area where there's no grit to get in. I've also heard of working the thinnest feeler gauge blade in there to clean it.
They make a special tool now for fork seal cleaning .....
http://sealmate.net/
If you don't have the special tools needed to do some of these jobs then about your only option is to take the bike somewhere and pay to have it done. I think a fork oil and seal change typically runs around $100. Makes the $5 (or less) special tool needed to hold the damper rod from spinning cheap by comparison.
In a pinch, you can tie a bandana just beneath it to keep the oil from shaking off onto the brake...
Every vehicle in that place became a rat vehicle. Oil was coming down the leg and shaking onto the disk, like a dog shakes off water. The bandana did the trick and I soon had brakes again. It was there for a thousand miles or so, and after a good wash was none the worse for wear. I carry it in my back pocket. You can't see the detail on it but it makes me an honorary Texas Ranger....
Well boys you shamed me into it.
I went to the local Ace Hardware to get a 17 mm bolt for the plugs. No joy They had 16s and 18s but no 17s .Anyway one step closer.
Bearings changed, I had some leftover automotive black acrylic. I've found that if you load a small brush and spread the paint quickly it has enough time to flow but is too thick to actually run. I did the whole frame except for underneath. I'll do that when I swap in a new unbroken center stand.
You're not looking for a 17mm diameter shank bolt, you want a 10mm diameter one. They routinely have the 17mm diameter head on them that you need.
