Well sportsfans, I granted myself a 2-hour reprieve from working today to try to get Lucille's slender but attractive 34mm legs back in good shape. You will recall that in June 2017 I replaced her fork tubes, oil seals and I also replaced the original dust seals with a pair of MikesXS rubber dust seals.
After two years of service, the dust seals have totally died (see above) and so I did what I should have done in the first danged place and tracked down a set of OEM dust seals. Today, I replaced the shredded MikesXS parts with the OEM items and things look MUCH better now. Along the way I ran across what seemed like a pretty cool little tool - the Seal Mate - that claims to prolong the life of fluid seals by cleaning grit out of the seal while it is still installed in whatever it is installed...in (yuk - poor grammar there). Sorry Winston Churchill, who once declared that "ending a sentence with a preposition was something up-with-which he would not put").
But, I digress....
I am a sucker for tools...so I bought a couple from the Canadian parts supplier FortNine.com (www.fortnine.com) and soon, I had four of these things to play with.
Anyhow - the Seal Mate (photo below) is a devilishly simple little item that consists of a sheet of plastic (thinner than a credit card and somewhat more flexible) with a hook shaped profile. You are instructed to slip the hook portion down between the seal and that which the seal is...sealing (geeezz..I'm still doing it again). Then you rotate the Seal Mate around the item and "dig" out any grit or other debris which is supposed to leave a nice clean slidey surface for the seal to..you know, seal (and no smart-@ss cracks about "blown seals" or "seals taking a leak" please).
Here is a video of the Seal Mate tool in action:
The issue I have is - that I could NOT get the Seal Mate down into the oil seal on Lucille's forks.
I tried and tried and eventually messed up the tool to the point where <I think> it is ruined.
Soooo....much as I like Motion Pro products, and I did follow the instructions, I simply could not make this thing work. Accordingly, I must label the Motion Pro Seal Mate as - a FAIL (along, of course, with the MikesXS rubber dust seals - which will come as no surprise to many on this forum).
Fortunately, I have three more Seal Mates to mess around with and so if anyone has a better experience with the Seal Mate - please comment and tell me how the heck you got the thing down in there....'cause I couldn't.
Pete
But, I digress....
Pete
