...Describe "hovering fog"
Haha, I guess I slip back into '70s lingo too much. Maybe there's a modern term for this phenomena.
When you view down the throat/venturi of a carburetor during full-throttle operation, you'll normally see fuel spraying out of the jet(s) like paint out of a paint gun.
With reversion, when the reflected exhaust pulses travel back thru the intake valve during overlap TDC, this 'spray' appearance becomes cloudy.
With severe reversion, at a specific rpm, this cloudy appearance takes on the appearance of a dense fog, that seems to just hang there, almost as if it isn't making it into the engine, just kinda 'hovers' there. In fact, the engine torque will be way down at this point, because it's not ingesting fuel.
The upside to this is that when at the higher appropriate rpm, the engine inlet/head/exhaust pulses combine to provide scavenging that can increase the engine's volumetric efficiency well beyond 100%, and torque skyrockets.
You can see the HP/Torque curves of these engines and see the telltale dip and peak of the torque curve. The depth of the torque dip is an indicator of this 'reversion' zone, the peak being the 'scavenging' over-ingestion zone.
An engine that ingests the same air/fuel mix at all rpms would, theoretically, produce a flat torque curve. But, since sound/acoustics figure into the breathing equation, you'll get these low/high flow zones, depending on the system's harmonics. Engine system designers do things to mitigate these effects, like that 'back pressure' thing. Racing engine builders go the other way, to maximise the effect.
(Sorry, brain ran outta steam)...
