1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
gggGary's latest XS project "madness"
Discussion in 'The Garage' started by gggGary, Jun 13, 2013.
  1. Jim
    Jim The thrill of victory and da agony of da feet. Top Contributor XS650.com Supporter
  2. Jim
    Good. Was gonna point out that it's prolly too close to exhaust port... :boxing:
    Tim Meaders likes this.
  3. gggGary
    gggGary Stop that! Top Contributor XS650.com Supporter
    Guess #2, getting a little warmer.
  4. gggGary
    Hogtied for the win!
  5. Wow! I was being a smart-ass. Guess I failed miserably.
    TwoManyXS1Bs, gggGary, peanut and 2 others like this.
  6. peanut
    peanut XS650 Guru Top Contributor
    I was gonna say drug running stash hideaway :)
    hogtyed, gggGary, Jim and 1 other person like this.
  7. gggGary
  8. racerdave
    racerdave ^ Gone not forgotten ^
    Yes
    gggGary likes this.
  9. gggGary
    swapped back to the old Mike's or WHOever muffs
    These headers don't have lower tabs but with the long mufflers I was able to hose clamp them tight to the factory header brackets, should be good.
    got the O2's in
    and the system fired up and worked, :smoke: Pretty much need the tank bag at this point, there are many "extra" feet of cable. I need to run a calibration yet and then I can set to doing some adjustments. As it is adjusting an idle mix screw made an instant difference on the AF reading. As I was suspecting, the needles are pretty good (on top clip) ie lean as I can go on them, and the mains are stinking rich. Plenty to do, :whistle:
    racerdave, YesX650, kiwi and 10 others like this.
  10. Jim
    Dang Gary.... I can see tons of cool experiments with that setup.... tune for existing pipes and see what affect different muffies have. Same with the air filters.... tune for your pods and then see what the stock boxes do to AFR.... play with timing... the list goes on...
    Like Pete would say... "damnit... I'm comin' over." ;)
    MaxPete, racerdave, MrBultaco and 4 others like this.
  11. Gator xs2
    Gator xs2 XS650 Enthusiast
    59
    54
    18
    FL
    Nicely done!
    Mailman, Jim and gggGary like this.
  12. Mailman
    This is all very cool. I understand that the o2 sensors can help tell you if you are running too rich or too lean, but how do you know what kind of baseline numbers you should be hitting?
    gggGary and Jim like this.
  13. TwoManyXS1Bs
    Bob, take 2 aspirins, and Google "stoichiometric ratio".
    The ideal stoichiometric ratio with good gasoline (octane) is 14.7:1.
    The ideal stoichiometric ratio with alcohol (ethanol) is 9:1.
    Expect something less than 14.7 with our modern gasohols.
    At low-throttle cruise speeds, carbureted intake manifold vacuum is high, and vaporization is nearly complete, expect high stoichiometric ratio.
    Full-throttle, high-rpms, carbureted intake manifold vacuum is low, time to vaporize is shorter, vaporization is incomplete, fuel droplets exist during combustion, incomplete combustion, expect lower/lowest stoichiometric ratios.
    MaxPete, lakeview, Mailman and 4 others like this.
  14. Mailman
    Wow! This is complicated, I think I’ll go polish something. :unsure:
  15. arcticXS
    arcticXS XS650 Junkie
    CEV gauges from a Ducati? Nice setup!
    Jim likes this.
  16. gggGary
    A modified set of NLA MikesXS gauges.
    MaxPete, Jim and Mailman like this.
  17. arcticXS
    They sure do look exactly like the mid 90s oem Ducati Monster CEV speedo, and Ducati Performance aftermarket CEV tach.
    MaxPete, gggGary and Jim like this.
  18. gggGary
    Was doing jetting changing gas tanks so figured I'd swap in a an 82 breather, the old one had no restrictions and was blowing phlem like aqualung, going to see if I can plumb it Into the uni filters. 1560374038888-1894992228.jpg
  19. arcticXS
    I also replaced my stock, twin outlet breather, with the later single outlet version, and hooked it up to this reed valve/check valve:
    https://www.heidentuning.com/xs650-...kcase-ventilation-valve-reed-type-detail.html
    It seems to work great, I just hooked a short, vertical hose to the reed valve outlet. So far, not a single oil drop has escaped, and no oil leaks either.
    The ideal solution would obviously be a vent housing with an integrated reed valve.....
    MaxPete, YamadudeXS650C and gggGary like this.
Share This Page
