Phenomenal progress on the swingarm today! Finally got some time in with the Bridgeport; looks like the swingarm portion of the monoshock conversion will be complete this weekend.
Started out with the welded swingarm mounted to a base fixture.
Painted with layout fluid and some guides scribed in. Centered on the tube, 4-3/4" behind the center of the main pivot.
After the base fixture was solidly bolted to the table, we turned a bronze rod down to a tight slip fit, ~16mm, and chucked it in the Bridgeport.
Using the threaded adjustment built into the fixture, along with this quickie tacked-on turnbuckle, we tweak the swingarm until the bronze rod is a perfect vertical fit into the swingarm pivot sleeve. The idea is to make all further drilling/boring/reaming operations perfectly parallel to the main pivot.
An additional brace is welded in, then the whole thing is re-checked for plumb.
After confirming my center marks with the
wiggler, the first cut is with a 4-flute 1/4" end mill. Unlike a drill bit, this has almost no chance of wandering off center.
Second cut was with a thin-kerf minimal-set 7/8" holesaw running at 160rpm...
...followed by a 1" ream running at 120rpm.
With three layers of steel, curved in two directions and sloping away from the perpendicular, there's plenty of room for error, but the solid jig and careful setup turn out to be worth the effort!
The second bore is trickier; the end mill won't reach through to start the the hole. Instead, we transfer-punched a center and drilled a 1/4" pilot with a long bit and a steadying bushing clamped to the table. (Knew I forgot to get a picture of something!). Here, we're set to run the 7/8" holesaw through. The pilot bit in the holesaw mandrel has been replaced with a smooth 1/4" rod, so it can't catch in the pilot hole.
It took the full travel of the quill, plus a little travel of the knee, to get the 1" ream all the way through. But after a couple clean passes, the dogbone pivot shaft is a
perfect fit.
I have my fingers crossed that the welding will be finished on Saturday!
