Brett
(1982 XS650 with TCI ignition)
I can't start my rebuilt bike with my simplified wiring loom! It started and ran before I rebuilt it. I posted the wiring diagram here on my previous post:
http://www.xs650.com/forum/showthread.php?t=19007
It looked like I wasn't getting a spark, so I tested the voltage across the primary terminals on the coil, and there is three volts less than at the battery!
What could be causing that?
I tested the resistance across all the coil terminals and that's fine. I've had the rotor and stator rewound because there were some problems there. I've checked the Tricon kill switch and there's no resistance across it when on.
One strange thing: When I switch it off at the kill switch or ignition switch, after trying to kick it over a few times (it's kick only), it coughs back through the carbs or exhaust.
I really want get it started. I'm sure the wiring diagram is right. Anything else I can test?
Thanks
Thanks
