View attachment 126090 View attachment 126089 View attachment 126088 I FIGURED IT OUT*****
So I cleaned the rectifier after I had it off and thought well maybe I should plug it in at the side of the bike (instead of completely reinstalling it) and test the battery voltage again. So I plugged it into the plug and then took a alligator clip jumper and attached it to the ground of the rectifier and then attached the other side to where the battery grounds to the frame under the seat.
I started the bike up, got my multimeter on the battery and throttled up. It worked! My voltage climbed from 12.5 all the way into the mid-14v’s. I’m like oh, the ground on the rectifier was shit.
So I cleaned it up all pretty, reinstalled the rectifier, put the ground loop back on the bolt that goes through the rectifier (and mounts it to the bottom of the battery box), started it back up, and NO CHARGE.
I’m like, ok, the ground underneath the battery box isn’t clean enough then. So instead of pulling the whole rectifier again, I just loosen the nut that holds the ground in place, remove the ground wire loop (while leaving the rectifier still tightened to the bike), I put my jumper on the rectifier ground like I did before and ran that up to the battery’s ground again. I started the bike...and something strange happened...the battery still wouldn’t charge even though it did before with the rectifier grounded with the jumper.
At this point I’m like what the f*ck. So I remove the rectifier so it’s not attached to the battery box and is just hanging by the wires underneath it not touching anything, I still leave the jumper on the ground from the rectifier and have it connected to the frame where the battery grounds under the seat like before....
And guess f*cking what?.....
The rectifier starts doing its job again and starts charging the battery.
SOMEONE EXPLAIN THAT.
My only guess is that somehow when the rectifier is attached to the bike it’s shorting the rectifier out somehow. If the ground didn’t have a good connection when I reinstalled it, it SHOULD have then worked when I ran a grounded jumper to it while the rectifier was still attached to the bike. The only time the rectifier sends charge to the battery is when it’s not mounted on the mounting bolt underneath the battery box.
Can anyone who’s smarter than me please tell me what the f*ck is going on? The pictures show what I did to make it work.
