So, I'm fitting firestone Deluxe Champion tyres to my 78 SE. It has the mag wheels (19 front, 16 rear)
Went and bought inner tubes for them today and when I put the tube in the rear I realised that the valve stem hole is way bigger than the valve stem (bigger than the hole in the front wheel too). As a result the locking nut doesnt clamp the valve / tube to the wheel, infact if you tighten it up it would just go through the hole.
Is that normal for those 16in wheels or has someone widened the hole for some reason?
How can I resolve it so I can fit the tube? Can I simply use a washer or would that be dangerous as there would still be play in the valve stem. I'm worried that the tube could sort of hernia into the space between the valve stem and the wheel and potentially pinch / pop!
What do you think? Does it need some sort of rubber insert?
Also the other tube for the front is a different brand (chen shin) and has 2 locking nuts then another nut which is tight up against a sort of shield which is then tight to the valve stem seat. Does that nut and shield go inside the tyre and then the other 2 lock on the outside or do all of those pieces go on the outside?
Sorry, never put tubes on a moto before. Advice needed! Cheers
