Rd51
Now I can drop the frame off for powder coating.
What a PITA that was! Having the tank cleared; keeping the numbers matte.
Love the brown and silver combo! I may have to cover my seat in brown when it finally wears out!
When you put the head gasket on did you use any threebond? I think it was 5twins that had a diagram of how to put a small bead of it on there to help prevent possible oil leaks later. And once you get the motor turning over a few times your cam chain tension will change and will need to be adjusted again so no worries at this point about the acorn nut on the cam chain adjuster.
it depends on the quality of the gasket but I believe I've read some do reuse their head gasket but frankly for the sake of less than $10 why risk it ?
If you do take the head off again don't forget its easy enough to remove and replace the cam without breaking the camchain
If I were you I'd run the engine now you've got this far. Provided you retorque after the first run and again later on (200 miles ?) it might be perfectly ok. Looks like you have been pretty careful about your build .
That engine just looks good man!! BE prepared to reopen side covers a few times! I had to 3 times! Glad there is no oil in her yet!
Why no mockup with the seat and tank??!?!? DO EEET!!! DOO EET NAAAO!!!(Arnie accent!!)
thats good progress Rd51.......... the engine looks great with the black accents.
