angus67
Welder's penetrate deeper!!
wow. good luck gettin that cover off, gggary
yes it should be easy no more than a gentle tap or two at most something is not lined up properly. show us a picture of the inside? There is a bit of a trick to getting the kick start spring lined up and in the right place.
To make up for my previous off topic wander here's some pics.
on reassembly it helps to use the kick arm to rotate the shaft till it goes all the way in.
Line up the the two spring ends slide the shaft in. then rotate it till the sector on the arm can drop in to the area where it travels.
I think the tension of the "clip" that holds the Bendix may be your issue, a search will reveal some previous discussions on that. I believe XSjohn will weigh in on those discussions.
This bike may have had an "incident" in it's past, You think?
But I think the motor is a runner!
Now I need to scrub my mind...........tranny shafts
