Hmmm... I just noticed that the spring boss was missing (knocked off by PO) and that the spring hook was resting on the case wall. Has been working fine though. Browsing the forum I came across a solution for this. Drill a hole, making threads and use a bolt locked with a nut. See images.
Anyone more that have experiences this problem and have tried this solution or have come up with another one?
Also, is it possible to drill a hole with only the cover off and covering the kick starter axle hole with a rag or something? Then just clean the clutch area well from possible drill flakes?
Or will you, when drilling, drill completely through which would cause metal flakes getting into the engine?
/Martin
/Martin
