ninskrillz
- Messages
- 271
- Reaction score
- 67
- Points
- 28
Hey guys and gals, I come to you with a problem I've been trying to solve for a couple weeks now. The left cylinder on my 71 is not firing as strong as the right. I believe it is causing inconsistent idle and pop stalling at idle or closed throttle.
I've tried a plethora of things to get it going properly. I've set valve spacing accordingly for my model, swapped plug leads to ensure the pamco ignition was working properly. I've been through the vm carbs multiple times making sure all passages are clear, needle set appropriately, float height correct, float condition perfect, and that the carbs are sync he'd properly.
I have not been able to do a compression or leak down test as I don't have the appropriate tools to do so. Is that my next step? Any other things I can check would be great. Would love to get some feedback if there's anything I'm missing.
