I have no information there is a brown wire from the ignition to headlight switch.........
I see the confusion I caused. I got in a hurry and had a little brain fade. I should have said in the run position the red/yellow is power to the headlight on/off switch.When the key is in the 'run" position the brown going to the headlight switch powers the blue to the tail lights. When the ignition switch is in the "park" position the ignition switch feeds the blue. Since the blues
In #2/park position the taillight and tach/speedo lights are always on. The headlight will be on if the headlight on/off switch is on.I think when the key is in the #2 position, that's it's in Park Light mode and only the tail light comes on. The key comes out and
you can lock your bike. Pardon me if this has been discussed.
What you’re seeing there is the wires for my aftermarket pressure activated front brake switch. I needed a couple bullet connectors to tie into my harness and they were what I had on hand. Yeah they’re not the best.Something else to check is the blue crimp connectors you have.
As far as the ground for your switch assemblies goes, later bikes had a ground wire in the left control running into the headlight. There, it connected to one of the ground wires coming out of the main harness. In the switch, the ground wire connected to the housing. Clamping the housing to the bars transferred that ground connection through them over to the right switch housing. But your early model may not be like this. I've heard it mentioned that some of the earlier models had a separate ground wire attached to the bar mounts.
I've also heard it mentioned that this ground wire then attached to the triple trees or headlight bucket. That's really not a good way to establish a ground. To complete the ground connection back to the main frame, it would have to flow through the steering head bearings. Bearings freshly packed with grease may not transmit the signal very well. That might explain the intermittent functions you got. There's also the possibility of sparking occurring, and that could damage the bearings.
So, I'd say you need to examine your control assemblies carefully to see if either contains a ground wire. If they don't then one will need to be added to the handlebar clamp. I would run that one either into the headlight to a ground wire coming out of the main harness, or directly back to the main frame.
Lookin' good! I'm sure you can "sneak" a wire in there, that'll look like it belongs. "The Basketcase" had several braided wires for grounds, here and there, with "eye"-end connectors. You can never have too many redundant redundant grounds. Most electrical fixes start with "did you check the ground?".I still might run a sneaky little wire just for back up.
Your bike was relatively unmolested when you got it. You don't recall finding a ground wire attached to the bar clamps when you took it apart?
No I don’t, this whole thing is something of a mystery to me. I wound up being able to get out in my garage for a couple hours this afternoon and I started tearing into handlebar switches and headlight bucket AGAIN !
I opened up all the switches, took inventory of wire colors, then checked inside the headlight bucket, to see what was coming out of the wiring bundles on the connection ends. I thought I made a major discovery early on, I found a black ground wire inside my brand new reproduction kill switch. The terminal was loose and barely making contact. I tightened it up but it made no difference, then I realized it was only a ground jumper wire from the kill switch housing to the starter lever. That ground wire never comes out of the loom inside the headlight bucket.
View attachment 135779 View attachment 135780 View attachment 135781
So I opened up the left side handlebar switch and looked for a ground wire, there was none. I cannot for the life of me figure out how the handlebars were grounded. So I decided to just put an end to this. Inside the headlight bucket I disconnected one of the wiring looms from the the left handlebar switch and I fed a black wire through it. I put a terminal end on it and attached it to a screw inside the switch housing, I also shined up the housing where it contacts the handlebar. The other end of the black wire inside the headlight bucket got a bullet connector crimped on it and I plugged it into an empty plug on a main harness ground wire.
View attachment 135782 View attachment 135783
I pushed the wiring loom back up into place and closed everything up and SUCESS!!! Grounding issues resolved.
Starter works, horn works, YAY!
I ran out of time and I still need to run down the tail light issue, but you guys have given me some good direction to look at.
Later,
Bob
GLJ said: ↑4. The rear tail light when the key is in the on position / IT DOES WORK when the key is in the number 2 ( Park ) position.
Good fix running ground wire through loom to switch.
I've looked over both of my 72s and can find no ground wires running to the handlebars, yet they both are grounded. It is confusing because as we know the handlebar mounts are rubber mounted. And as 5Twins pointed out the ground would also have to travel through the steering head bearings, which is not good. I think you have effected a very good solution.
GLJ said: ↑
Does your headlight work?
GLJ said: ↑
What about the speedo/tach lights?
Yes and yes.
I rereading your tail issue. I believe your ignition switch is good. Headlights work in run so its powering the Red/Yellow. Taillight works in Park means it's powering the Blue. I think you need to check the Blue wire coming from the headlight switch for power when the key is in the run position and the headlight on/off switch is on.
It should be one of the blues on the left side of the double female connector. If you have no power on the blue when the headlight is on you either have a problem with the wire/connection or the on/off switch is bad. Good luck remember meters are your friend.
Your new right switch assembly looks very well painted, probably too good in the areas that clamp against the handlebar. I assume you cleaned the paint off of those as well.
