And here we go!!!!!!!!!
First time this motor has ran in seven months!
This video is actually the second start up. The first start I was busy checking timing and the charging.
It is charging beautifully ( Thanks Jim! ) and the timing was dead on. I did not have to touch the carbs after starting, it idles perfect, throttle response is crisp with no stumbles. To say that I’m relieved would be an understatement.
Mostly all I did was clean things up and hone the cylinders. Same rings, no new parts other than a couple seals and gaskets. So to see it run nicely right out of the box was a huge relief.
Turn the volume up, it’s kinda low.
Wooo!
