Well, first a little vocabulary lesson:
1. A "short" is either a direct path from power to ground (hot lead touching the chassis for instance) or an unintended path between two wires (insulation rubbed off).
2. A fuse doesn't "short" it "opens" or in more common terms "blows". It does this because a "short" (see #1 above) has caused excessive current draw and the fuse blows to keep the wiring harness from melting down and/or starting a fire.
Now that we have our terms clear, your fuse is most likely blowing from one of three reasons:
1. You have a main power lead shorted or partially shorted to ground, usually due to worn insulation allowing the wire to touch the frame or some other metal object.
The solution here is to visually inspect the entire wiring harness looking for rub points, worn or cracked insulation, partially undone connectors, etc.
2. A component (switch, ignition module, light socket, reserve lighting unit, or any one of several others) has failed or is failing in such a way as to create an overcurrent situation.
The solution here is to unplug each component one at a time and see which one causes the problem to go away.
3. Someone has replaced the fuse with a fuse of too low a value. IIRC, the main fuse should be a 20 amp fuse. If it has been replaced with say a 10 amp, then normal loads may cause it to blow.
This doesn't cover ALL the possibilities, but it does address the most common causes of blown fuses.
Check it out and let us know what you find.
Edited to add: Your dim neutral light and eventual stalling indicates an overload pulling the battery voltage down. The ignition on XS's requires full battery voltage to work properly. All of the investigative steps above apply.
