1. Dismiss Notice
    Dismiss Notice
Master Cylinder Rebuilding
Discussion in 'The Garage' started by littlebill31, Apr 20, 2011.
  1. littlebill31
    littlebill31 Smells of Raw Fuel
    This will cover the procedure for rebuilding the front brake master cylinder (m/c).
    All 3 types will be covered.
    There are 3 stock types of front brake master cylinders on the XS650.
    The original Round Cover:
    insert round assembled here
    The "Standard", which has no angle, straight body:
    And the "Special", which has an angled body to "clear" the Buckhorn handlebars:
    The inside of the reservoir on all 3 types are also different:
    Round Type:
    [​IMG]
    The "Standard":
    The "Special":
    NOTE: Brake fluid is a dangerous substance. DO NOT let it come into contact with painted surfaces. Immediately clean up any spill and wash hands thoroughly. Keeping a "more than normal" clean area when working with brake parts is very important!
    Makes sure you read this in it's entirety and thoroughly before beginning.
    To begin, First drain the system using the bleeder nipple on the front brake caliper. Refer to the Bleeding Brakes How-To if you are unaware of the proper procedures to do this. Drain as much fluid out as possible to reduce spillage from the reservoir.
    Using the center stand or leveling the bike is a good idea when doing any maintenance.
    Open the top cover of the master cylinder after draining the fluid. Put the cover, diaphragm, and diaphragm bushing in a safe place for later inspection/cleaning.
    You can use a rag to "sop" up the remaining fluid. Do not get this fluid on any painted surfaces.
    Disconnect the brake line from the m/c. Remove the banjo bolt and 2 washers.
    [insert picture]
    Remove the 2 10mm bolts from the m/c clamp and remove the m/c from the machine.
    NOTE:An above average cleaning area is needed for any types of brake repair.
    Turn the reservoir 90 degrees to prepare for removal.
    Using a thin instrument, CAREFULLY raise one corner of the reservoir from the m/c body. There is a large O-ring that the reservoir must be separated from.
    Work your way around the reservoir to loosen and raise it.
    Then you can "pop" the reservoir off of the m/c body.
    You can now inspect the inside of the m/c body and large O-ring. Notice the hardened brake fluid and grime that has collected between the reservoir and m/c body.
    RadMax likes this.
  2. gggGary
    gggGary I'm listening, change my mind XS650.com Supporter Top Contributor
    Great start! Thanks for all your hard work Bill.
  3. littlebill31
    Remove the large O-ring from the body. it is a good idea to replace this, but if there is a very good seal, the ring is smooth and pliable, you can reuse it. If the reservoir was leaking between the m/c body and reservoir previous to removal, then the O-ring is suspect and should not be reused.
    Inspect the reservoir for cracks, nicks, and poor condition.
    You can now remove the brake handle.
    BEFORE! you separate the handle from the body note that there is a spring in the m/c body. Once you take the bolt out catch the spring by slowly remove the lever.
    Notice the poor condition of the piston. This is caused by the brake lever adjustment screw. Over time a "pocket" or "dimple" will begin, which can cause the improper brake lever pull.
    There is a small rubber cap that fits over the piston. This is a sealing point. If brake fluid has been leaking out from around the lever and piston this "boot" could be the cause. It looks similar to a top-hat.
    Remove this from around the piston. I would not reuse this!, so a pair of needle nose pliers will help it off. You will also notice that there is an internal wire in the bottom lip of the boot. This will corrode over time and will fail!
    RadMax likes this.
  4. littlebill31
    When the boot has been removed you can now look into the beginning of the piston bore.
    Note the brown fluid. This is old brake fluid, so imagine what the inside of your lines and caliper look like. You must treat the entire braking system as one. Do Not fix one part and neglect the others. Brake fluid moves up and down and all throughout. So if you just rebuilt the m/c and not the lines or caliper, you just wasted a bunch of time and money.
    Now for the fun part. Piston removal.
    In order to remove the piston you must first remove the internal snap-ring. This "ring" is a pain in the butt, seriously. I never reuse this ring nor should you. It will be corroded and, after trying to work it out, will be damaged.
    This ring has 2 small holes on the end so snap-ring pliers can be used to remove it. Not all snap-ring pliers will fit. You will need a pair with long, thin extensions. The inside of the bore is narrow and deep.
    I also loosen the ring by using a punch to insert into one of the holes and turn the ring in place to free it. These rings will be corroded and will probably need to have brake cleaner sprayed into the bore, let sit, then follow with a penetrating oil.
    If you can use the pliers, then reach down into the bore and remove the snap-ring. I will say that this is tough to do, but can be done. Just make sure you have the correct size pliers, the correct tips (not too big), and internal pliers, not external.
    If the snap-ring will not come out or you do not have the correct pliers, you can use a punch. Simply put the punch in one of the ring holes and CAREFULLY press it towards the piston center while using a slight upward twist. This will usually free it enough to "pop" it out of the groove. You can then use needle nose or a hooked end punch to remove it the rest of the way.
    WARNING!! DO NOT damage the interior of the bore. If you damage this the piston will not work properly. Getting mad and scratching the bore will cause you to have to buy another m/c body!!
    RadMax likes this.
  5. littlebill31
    Thanks Gary. I lost some picture so I'll have to re-take them. But it's a start.
  6. gggGary
    It's really good work, you could be a tech writer no problem. I think this is ready for prime time.
  7. littlebill31
    Lol, they're your m/c's too. I only had a little time this morning to work on it. Will continue tonight.
  8. littlebill31
    Once the snap-ring has been removed, throw it away, do not reuse it!!
    The piston should pull straight out. If it does not then I suggest using a wooden dowel rod. Place the wooden dowel rod in through the banjo bolt hole, center it on the bottom of the piston, and tap it until it becomes free. I do not suggest using anything metal for fear of damaging the bore. A couple turns of the piston can help free it as well. the are usually pretty gummed up and corroded from neglect.
    This is a really bad piston!!
    Here is the bad one and a used one that has been maintained over the years.
    Next, use a dowel or screw driver, being sure to not scratch the bore, and from the banjo bolt hole, push out the spring and end cap.
    Here are all the internal parts laid out.
    NOTE: It is highly advisable to lay each part out as you remove them. Mixing parts up or putting them back in, in the wrong order, can cause the master cylinder to fail.
    NOTE: The wide end of the spring goes towards the banjo/brake line end.
    You can now begin to clean the master cylinder as all the parts have been removed.
    RadMax likes this.
  9. littlebill31
    When you are cleaning the m/c body be sure to clean the small ports in the bottom.
    Here, on the "Standard",
    ..And on the "Special",
    Also note that the reservoirs are different on both types as well.
    The "Standard" cover screws are attached to the reservoir itself, not the body
    While the "Special" cap screws go through the reservoir and into the body
    Cleaning can be done with brake cleaner, a soft wire brush, and very fine grit wet sand paper. Most of the "gunk" will come off easily, but taking your time, and doing it correctly, will only produce a better outcome.
    Before,
    After,
    Make sure you clean all the parts, front and back. The old brake fluid can seep between areas, causing pitting and some rust.
    That second port is ( and must remain) TINY, smaller than your smallest torch cleaner pin or the smallest number drill. The hole is made at the factory using a special V shaped cutting tool that just pierces the piston bore. Several aftermarket MC's have been found with the hole not complete! Endless fun ensues.
    One way to clean a stubbornly clogged hole, sharpen a piece of stainless steel safety wire on the grinding wheel. or a small sharp sewing needle........
    even better is a 90 scribe or scriber.
    [​IMG]
    A very handy tool!
    Working up into the hole from the bore side. As you can imagine whatever is blocking the port settled there from the reservoir side, and needs to get pushed back that way CAUTION! do not scratch the piston bore or enlarge the hole!
    RadMax and gggGary like this.
  10. xjwmx
    xjwmx It's just the unknown. Top Contributor
    7,398
    3,499
    313
    U.S.A.
    Nice! And a lot of work!
    I wonder if some standard and special reservoirs are the same and you happened to get some that aren't. It would make sense to make them the same and share parts.
  11. littlebill31
    The m/c's were donated by gggGary. There is a difference in them all. Even the piston bores are different.
    As you can see the Standard is beveled:
    While the Special is not:
    RadMax likes this.
  12. atomic22
    atomic22 XS650 Addict
    Really awesome work. I'm actually rebuilding my front brake as we speak.
    Instead of using brake cleaner to clean out the mc, is it ok to use purple power or something similar?
  13. xjwmx
    7,398
    3,499
    313
    U.S.A.
    ^I don't see why not as long as it gets clean. Although lots of chemicals react with aluminum.
    People recommend not doing any honing on them, since they're aluminum. I can see a brake hone cutting ruts in them and removing a lot of material fast.
  14. xjwmx
    7,398
    3,499
    313
    U.S.A.
    Do they all have normal right-hand threads for the mirror mount? Both my mirror mounts have normal threads, which I thought was unusual.
  15. littlebill31
    I think they do. Gotta check. The clutch, I think, is left-hand.
    If you need to uuse anything, use a very fine sandpaper. Like a "mirror" grit. 2,000 and use it very lightly. Just enough to get the oxidation off and that's it. Make sure you use it wet or with brake fluid as a lubricant.
  16. atomic22
    [​IMG]
    Bill or others
    How do you put the gasket(?) on to the piston? I can't seem to put it on with just my finger, and I don't want to damage it with a pair of needle nose...any suggestions?
    Thanks
  17. littlebill31
    Use some brake fluid as a lube and bend it around. It's tight for sure.
  18. gggGary
    blow up of an early master cylinder with lever parts.
    [​IMG]
    This is a 72-73 M/C with the brake light switch held on by the lever bolt.
    A cotter pin at end of lever bolt is not shown.
    To remove the lever from the housing; the brass bushing is threaded onto the bolt, the steel sleeve is a slip fit, remove the cotter and nut, pry the brake switch off the retaining pins. Using aluminum or brass to protect the threads, tap the bolt and brass bushing together up out of the housing to free the lever.
    72-73 Internals in assembly order
    AFAIK there are no overhaul kits available for this MC
    Ebay and mikesXS have new replacements for the 74-76 but they do not have provisions for the 72-3 brake light switch.
    RadMax likes this.
  19. jd750ace
    jd750ace Front Toward Enemy
    Great series of pics and notes! Thanks guys!
  20. RPC3
    RPC3 XS650 Addict
    On the reservoir o-ring (first and second pictures on your second post), it doesn't look like the fiche has a part number or size listed, and the rebuild kits don't include one. Any idea what size that o-ring is or a good place to get it would be? The only one I've found is:http://www.ebay.com/itm/like/331127448517?lpid=82and it doesn't say if its year specific or not.
    Great job with the write up, I've got my M/C in pieces at the moment so this is perfect for me.
Share This Page
