bobber bill
- Messages
- 296
- Reaction score
- 1
- Points
- 16
I got one of those mini batteries that are the size of a cigarette pack. This thing has tiny little wires coming out of it which raises some questions:
1. Should I solder in some heavier gauge wire after the 20A fuse on the red wire?
2. What about the black wire? How should I ground the battery and the rest of the bike's components? Do I ground the battery to the frame? and then ground all of the individual components to the frame as well?
3. Or should I run one thicker continuous ground wire directly from the battery to the rest of the components?
I'll be running a Pamco ignition and PMA conversion. Headlight and tail/brake light only
Any info is appreciated. If you have pictures, even better! Thanks
