Meddy
Thanks Tom, good to here from another "local" owner. Yeah, happy to organise a meet up sometime, not many 650 owners down my way, I've only seen one other in 20 years of owning mine.
My Rd350 disc looks like yours. What grit flappy disc did you use?I managed to get back in the shed again on the weekend after the Christmas festivities, temperatures a bit different here to what you Northern hemisphere folk are experiencing, 42c here on Saturday.
Started work on the brakes, cleaning up the rotors and painting them. I mounted one of those flappy disc things from an angle grinder into my bench drill and used that to clean up most of the crud, then followed with a brass wire brush in my cordless drill.
A couple of before and after pics.
View attachment 111722 View attachment 111723
Please let us know sometime if the pads are quiet when you apply the brakes.
Perhaps you could turn that into a cylinder head temp indication?This particular model is made for a DR650 Suzuki, so it also comes with an engine temperature gauge, not sure how useful that will be but it's an interesting novelty.
One of my goals for this project has always been to be able to start the engine before I get too far into the build. I was now at the stage where this was very close and having a couple of free days I decided to have a red hot crack at getting this old girl going.
First off I had some wiring to finish as I had not done anything with the charging circuit. I have been reading up and checking out different wiring diagrams for some time now so I was pretty sure how I wanted it all done, so I spent a fair bit of time on that yesterday getting it all neat & tidy and testing all connections as I went. So far so good.
Next I had to reassemble the tops of the carbs as I had pulled them apart again after 5twins advice on them having the wrong needles. ( I figured the old ones would do for testing purposes).
I had the battery on the charger overnight just to make sure it was fully charged, so today was just a matter of fitting the carbys back on and connecting up my temporary fuel supply.
With the fuel turned on all looked good, then, a couple of drips of fuel from the base of the left hand carby! what!
No problem, just the drain plug needed snugging up a whisker.
OK, I was ready to go, key on, heart in mouth, and, believe it or not, I even had the fire extinguisher on the bench next to me, talk about self confidence.Not.
I hit the starter button, nothing! again, nothing! you have to be joking I think. I had checked and double checked all these connections, even had the starter turning the motor over when I bought the new battery.
OK, relax Mick, maybe you disconnected something when you were working on the wiring, I checked everything all good.
What about that safety cutout relay I think to myself. I gave it a smack with a screwdriver.
Hit the start button.
Bingo
You bloody beauty, it gave a couple of half hearted wheezes and then away it went, flick the choke off give it a bit of throttle and it was running, wouldn't idle at first till I upped the idle screw a turn or so, but there it was after sitting in pieces for near 20 years it was a runner again.
Ran it 3 times about 2-3 min each, could not see any oil leaks, so far.
I was keen to see how my wiring had gone on the charging circuit seeing as I was using a new rectifier (Ebay special) and a new regulator ( Bosch RE55)
Multimeter reading on battery engine stopped 12.9volts.
Engine running at fast idle 14.2volts, seems pretty good I think.
This is the first time I have ever built a motor from scratch, and I can tell you it was a magical feeling to know that I had been able to do this, so a big thanks to each and every member of this forum because it is from me reading and learning about this bike from all of your posts that I have been able to achieve this.
And here it is.......
Thanks MBX, I have to try and keep it reasonably tidy or I can't find anything, needs to be bigger, but there again sheds are never big enough are they?Cool!....great little shed ya got there too mate..and so tidy.
Bike looks very tidy too.
Yeah it's been a hot summer this year, and when it gets over 35C then I reckon it's too bloody hot,I really like the instrument setup and may have missed this detail Meddy - but how will you make the tachometer work?
No tacho on this model Pete, I figured I can just hook up the original for tuning purposes then take off again. I rarely rely on tachos when riding and I'll only be using the XS as a back road tourer so I'll only be plodding along.
Of course that might all change when I get it on the road
Geeeezzzz - Meddy - I just noticed the temperature reading: 41C (that’s over 105 degrees F for our US friends).
