The Carby rebuild.
When I pulled this bike apart all those years ago I literally just emptied the fuel out of them, wrapped them in an old T shirt and put the whole lot in a plastic bag.
I think I have been lucky.
Although the outside looked pretty average,
The internals were really good (sorry forgot to take pics of the strip down).
All of the screws undid nicely and there was no dried up deposits in the fuel chambers and all the passages seemed clear.
However I did find that the float level on the left side carby was way lower than it should be measuring at around 32mm in the upside down position, so I am thinking I may have found what originally caused the holed piston all those years ago.
It was obvious that a previous owner had been into the carbs at some stage as the main jets had some galling on them I also found that the Needles were marked as 4m1 which according to Carburetor guide on this site were used in 78 models and my 79 should have 502 needles.
The slides look to be in good condition with no sign of any perishing on the rubber I they drop very slowly when I pit my thumb over the oval port.
The only problem I had during this carb rebuild was when I went to fit them back on the bike. I had bought a new pair of carb holders earlier in the year from Ebay member cruzenimage, but for the life of me I could not get those carbs to seat on the new holders, eventually I took everything off the bike and discovered that the ones I had bought had the raised lip deeper in the mouth, so I am thinking I got ones for the later model carbs. I sent him an email to see if I can swap them, but I don't hold out much hope seeing as I bought them 6 months ago.
My original carb holders, showing about 4mm to the start of the ridge.
And the ones I bought showing about 8mm.
I have also been rebuilding the electrical switch gear whilst waiting for some parts to arrive. The write up that Peanut did on the ignition switch overhaul,
http://www.xs650.com/threads/ignition-switch-overhaul.46712/
and the one from gggGary on the Kill switch are a must read I reckon for anyone rebuilding these items.
http://www.xs650.com/threads/kill-switch-overhaul.49690/
My dialogue has now caught up to where I am in the rebuild process, today I spent some time cleaning up the old exhaust system and temporarily fitting it to the bike in preparation for me starting it up for the first time. I am still undecided on what exhaust to use so this will do for testing.
I also rigged up an auxillary fuel tank, which is just a brush cutter tank that I picked up.
And here's couple of pics taken today.
