I am Carbon
shade tree mechanic
Thanks Airwolfie. Your all right Man!
I had to wire up the repurposed speedometer
that went from 1 ground and 1 hot to 1 ground and 5 hots.
I also had to wire the light to the tachometer so that was quite a bit of soldering
Tomorrow I need to get some nice crown nuts for the install to replace the crap hardware that is on there
jdizon, it's not to bad Brother.
I printed out my wiring diagram and keep it where I can look at it.
also using different colored highlighter pens on the diagrams different systems makes it easier to read the diagram too. It's something that I do on blueprints too for that reason
As smart as I know you are. You will breeze through it my friend.
My best advice is make sure where you want everything before You start and make sure it will fit there too.
