Well, was able to ride the bike to work today
was able to finish wiring up the HEI module and GM DIS coil yesterday. got good spark on both cylinders. Messed with the carbs just a little bit and it idles between 1200 and 1500 real steady with a LOT less vibrations than before.
Tried to use the manometer with 20w50 oil for indicator fluid but all it wanted to do was suck it up the manometer into the motor...must be doing something wrong. I was connecting to the vacuum port in the carb boot so =shrug=. I had set the balance screw by hand when i was rebuilding the carbs. sighted down both carbs and adjusted the balance screw until they both showed the same amount of light past the butterflies at the same time on throttle opening. probably a good enough ballpark for now.
For the most part the bike runs well. although it seems to have a lean spot about 1/4 to 1/3 throttle under cruise. Open it up a bit more and she runs like a raped ape. Not sure if this is symptomatic of having sit for a month or so (had to fix a stuck float valve also, just dropped the bowl and moved the float a time or two and fixed it) or if its from the PO putting aftermarket mufflers on the bike. I currently have stock air filters in place. I also have a set of one step up mains and pilots in case i need to up either one... have to go re-read about how carbs work, so used to the programmable ECU on my car. I THINK i need to up the pilots if its that low of throttle and rpms (2500-3500ish).
Also did the spring mod on the old springs (snipped one coil off and bent a new hook) and greased the shaft and advance pivots. Advance seems to be working quite well now
Replaced the alternator brushes as well. One was worn way down the other only about half as much. bike seems to be charging well, but couldn't check as my VOM was broken. I'll check charging volts today with a better DVOM.
All in all, it seems like its slowly starting to come together. Probably have to replace the chain soon, running out of adjustment room. At least i can do that when i get the funds to switch to a 17/32 sprocket setup...
