xsleo - thanks for the pointers! I didn't get a chance to read your post until AFTER the motor was already out and mostly disassembled! I lucked out and once all the motor mounts were out, I was able to tilt the motor to the right a bit and lift it out of the frame using the kickstarter and the points housing. then I brute lifted it onto the worktable. Didn't realize it was that heavy...
As for the tear down and diagnosis...
Engine out - via brute stupidity...i mean young strength
and up on the workbench, via same method as above
Some ill omens in the oil filter
rockerbox off - only thing concerning is what look like grooves where the cam bearings were. can't feel any grooves though...
and found the source of those metal pieces in the oil screen...good old front cam guide is FUBAR
Not sure if the tensioner guide is still ok though, got some decent grooves in it. (also found the lock nut for the tensioner set was MIA)
and initial diagnosis of a holed piston confirmed. Interestingly enough both pistons had a fair bit of carbon buildup too...
blowout from the underside, looks like it not only melted through, but also had a pressure fracture event as well.
Hopefully the combustion chambers clean up ok. not sure if the aluminum spatter from the piston is welded to the head yet...
and where we are for now...in pieces
I did measure the top two rings (in their respective bores) and got some odd readings. from what I can tel from the Clymer's manual, spec is .2mm to .8mm. Also, the replacement pistons I have are 954 stockers and the # on the one good original piston is 953.
good piston
ring 1 - .711
ring 2 - .203
bad piston
ring 1 - .559 carbon stuck
ring 2 - .406
Also, I think someone was in at least the top half of the motor at some point, there was sealant all around the advancer housing and some of the valve cover plates had sealant on the o-rings.
Lastly, since I have the motor/trans torn down this far, is there anything else I should check? Is there anything that would drive further dis assembly and inspection of the motor and trans? Ideally I wanted to adjust the cruising rpms, but I was going to start with a sprocket change first. Funds permitting though, I may spring for Mikesxs' 5th gear as well...
I should start compiling a need/wish list at this point I think...
