I soldered every connection after that picture. I wanted to make sure everything was wired correctly before I soldered them. I guess I will start untaping everything until I find the problem again.
I believe my regulator is trashed. Did the green wire jump from regulator plug to ground and got a charge on the battery. I messed with a few connections to make sure it wasn't that and now I'm blowing fuses when I try the green wire jump. Any reason for this?
The main fuse would blow when I jumped the green wire at the regulator connector to ground. The first time I did it I got a charge on my battery. So I knew it was my regulator or the ground, I made sure all of the connections going to the regulator were good and still didn't get a charge. So I did the green wire jump one more time and blew the fuse.
Everything to the regulator was hooked up good so I ordered a new one. I'm just wondering if I screwed something up while I was testing the regulator which is causing the main fuse to blow. It only blows when I ground the regulator, not when everything is hooked up normally.
Any ideas why I would be blowing my main fuse jumping the green wire at the regulator connector to ground? It blows the fuse instantly when I touch the jumper to ground. I did it once and got a charge on my battery did it again without changing anything and started blowing the main fuse.
Unplug the rec/reg so its out of the picture. Ground the left (outer) brush (green wire), and then turn the ignition key on. If your rotor is good, you should have a magnetic field (slap test), and you should not blow a fuse.
Well, your rotor is working, so plug in the rec/reg, and if its good you should still pass the slap test (do not use any external grounding wires, let the rec/reg do its thing) , and the alternator should charge.
