Parts miraculously arrive so the bike’s back together. The exhaust reinstallation was super difficult. That took me close to 1 hour alone.
Carbs are adjusted and synced. Seems to run ok but can’t tell without a road test. Cleaning the front wheel will be my last task for the year, then beetle time again.
edit - when I first started the bike, the air cleaner was off and it seemed to be starving for fuel at higher rpm’s as I blipped the throttle. Installed the air cleaner and the motor ran quite smoothly. The restriction from the air filter must be richening the mixture. Pita though, to adjust the low speed mixture on the front cylinder, the air filter assembly must be removed. I’m thinking I should drill a hole through the air box to allow access to the mixture screw and glue in a through tube to keep the dirt out. I’ll have to see if that interferes with the air filter location - if you look hard there’s always something to do. lol.
