Greetings, gentlemen! This site has proven incredibly useful thus far, but at this point I feel I must reach out for help.
I bought an '83 heritage special. She was running good (albeit just a tad rich) but then a few weeks later, she started sputtering and generally sounded not very happy. After some troubleshooting I figured the ignition coils were done, due the ignition coils being reportedly known to fail. I tested it and sure enough, the readings were not up to par.
So I install the new ignition coil, and now it won't spark! Okay, so what else could it be?
Then, upon further investigation, I learn that the CDI units on these bikes are pretty terrible. Problem is, I can't seem to find it on my bike, and even if I did I can't find instructions anywhere on how to test it. Apologies, I am very un-knowledgeable with this kind of stuff.
Any help would be greatly appreciated... Riding season is almost over
EDIT: I am NOT using the "high tension plug wires" as mentionned in the catalogue for the ignition coils. Could this be my problem???
- Checked fuses
- Battery voltage good, fully charged
- Checked grounds
- Tested stator/rotor, good ohms reading
- tested ignition coil, (maybe it was DOA?) good readings
- Brand new spark plugs installed
