Just got a quote of $7.93 apiece for the copper crush seal from the Yamaha shop. Yes Mikes is cheaper till you figure shipping then the dealer wins. Don't need or want enough stuff to get free shipping so....
Some seaching is in order. Ain't this site GREAT!
@ 5twins, have you found a alternate source for these? I assume since you mentioned pairs you are talking Mikes?
@ Purplezinger, Would you consider the o-ring as a permenant replacement part? Not meaning buy one and use it forever, but switching to o-rings as oppossed to the copper crush ring?
As a side thought if switching to o-rings would you want to bevel the drain holes alittle?
@ Dusty, So I had it bass ackwards? The trick is to channel the plug, not bevel the base?
And finally a word from a master.
Another jewel copied and saved.
Thanks Grizld1!
Yes, usually the seal ring or gasket on the plug is worn out so the P.O. over-tightens it to try and compensate. When you order a new pair, order 2 pairs so you always have an extra on hand.
Once you get the plug out (and either way works, pipe extension on your breaker bar or remove sump /use vice to hold) If you don't have the proper copper sealing washer, in a pinch you can use a viton (rubber) "O" ring. Take the drain plug to farm store or hardware store and find a "O" ring that fits a little snug. I prefer farm store O rings because they usually for hydraulic use, were as hardware store O rings are usually for plumbing service. I've run many hundreds or miles using the O ring method while waiting for the copper seals to arrive.
I think it was me that mentioned the o-ring fix, but I turn a groove in the flange of the plug so as not to smash the o-ring. I have also heated copper washers red hot to soften them up.
Why wouldn't you recommend an o-ring ? I have done this to my last 3 650's, no oil leaks. I think most of the new engines run o-rings instead of gaskets. I think an o-ring is a clean,easy fix, and you don't have to crank the plugs down so tight that you risk stripping the threads.
Thanks Grizld1!
Re. annealing copper washers, gaskets, etc.: heat cherry red and quench. Quenching hardens steel but softens copper; it ain't the same stuff. The crush washers from Mike's XS aren't copper (they look like aluminum with a copper wash?), so don't try the annealing process on those. I have OEM washers with 30-plus years on 'em that work just fine.
