A lil' thread update to address this issue of binding MikesXS pump rotors.
Another relevant thread:
http://www.xs650.com/threads/mikes-xs-oil-pump-rotors.16545/
The OEM rotors should measure right at 8.00mm (0.3145").
On receipt of new rotors, you MUST measure the diameters and widths.
My measurements showed slightly thicker rotors. This is both a good thing and a bad thing. Bad, if you just plop them in there and install. The pump may bind and not rotate. However, it can be a good thing since the rotors can be easily lapped to a desired thickness, perhaps leaving them slightly thicker to reduce the side clearance.
Measurements of my rotors:
The outer rotor was 0.0025" oversized in thickness, the inner was 0.001" over.
Easily solved by lapping with #400 wet-or-dry on a flat plate. Occasionally spray some brake cleaner on all that to help with cutting and preventing load-up.
Using an orbital motion with medium pressure, make about 3-5 sweeps, then rotate the part about 90°, another 3-5 sweeps, continue. Do both sides, and occasionally measure all about to ensure that the thickness is consistent. It only took me about 2 minutes to knock off 0.002" from the outer's thickness, much less to knock off 0.0005" from the inner.
That left the new rotors with smooth lapped sides, and a finished width of 0.3150" (8.05mm).
Just enough extra width, 0.0005" (0.05mm) to bring the side clearance back to spec.
Interestingly, the outer rotor has a slightly concave/dished shape on one side. And, that is the side to do most of the lapping. This pic shows the lapped surface that appears about the edge of the outer rotor.
The assembled oil pump now spins freely...
