The inner hub should be proud of the splines. If it's not, the nut and washer will just tighten against the shaft splines and the hub will be loose
ZACKLEY!! The tiny protrusion gives the nut something to bear against.
Right now, I'm going with a worn basket bushing.
It can not only let the basket bounce around, but the mesh depth of the primaries can change, making sounds...
Found this pic. Will confirm again.A properly fitted 447 pressure plate is aligned with the index mark, and setting into the hub, its splines overlapping the hub's splines by about 3mm, as shown by these wear Mark's on the hub splines.
Huh, you're right, didn't catch that.Study this modified pic #4.
But, to be sure, need to do the "basket spin test", referenced earlier.
My apologies that I didn't get this done yesterday. Have read some of your posts on this 2M. I assume that I need to remove the primary gear #26 to do this?Rob, what you're grabbing and wiggling is the basket, not the hub.
This test is easier if the basket isn't in the way.
Grab the hub, try to move it up/down and in/out.
That tests the mainshaft's double-row bearing.
The basket's wiggling doesn't look good.
That's tested with the "basket spin test".
It, too, should demonstrate virtually zero slop and runout...
Ok, well that's good.The primaries gear mesh looks ok, they're aligned.
Just a quick test to ensure correct washer assembly.
Funny how tight it feels and yet the basket will still move around. Will do the basket spin test.Right now, I'm going with a worn basket bushing.
The shiftshaft's long dangly arm, and its claw arm, could be bent. They're easily straightened. Not much room for that thing in there. Closely examine the shift arms and the backside of the clutch basket for ding marks. More info in signal's thread:
You might wanna check your last repair too, the starter gear fix. Maybe something's not quite right with that assembly.
See if the mainshaft's double-row bearing, behind the clutch, looks damaged, or has any lateral play.
Do the "basket spin test", found in Paul's thread:
While doing the basket spin test, aggressively push/pull and tilt it, see if it contacts anything. Especially that spot near the crank primary bearing.
And, the end spacing of the basket's ID plus the axial thrust bearing and it's 1mm washer should be 0.002"
Agreed. That's the way I'd go Robin. At the least, swap the basket and bushing with whichever ones "feel" the tightest. Run it and see if the tic's still there. Judging from the video, you're not in any danger of grenading an engine.....then you’ve just knocked your original clutch assembly off of the suspect list.
My two cents.
