RPC3
Hi Guys - I'm ready to wire up my Pamco and wanted to run a few questions through the board to verify I've got things positioned appropriately and also to ask for some advice. Bike is a 1978E, I've got the stock harness (well, Mikes version of the stock harness) wired up, the Pamco kit purchased was the pamco with e/advancer and basic dual output (emgo?) coil. I've got everything physically mocked up, so getting close to finished. My goal is to leave as much of the stock harness in tact, just because I don't like the idea of cutting stuff out of the harness if I don't have to.
1) Wiring
With the points, old coils, and condensors removed, I'm left with
Harness:
Red/white #1 --> to red wire from e-advance box
Orange --> Cap off
Red/white #2 --> to one of the coil's male spade connectors
Gray --> Cap off
Orange (2 into 1) --> Cap off
Gray (2 into 1) --> Cap off
Pamco E-Advance Box:
Red Wire -->Red/white #1 from harness
Green Wire -->to one of the coil's male spade connectors
Black Wire --> ground to frame
Coil:
Male Spade Post 1 --> to red/white #2 from harness
Male Spade Post 2 --> to green wire from E-advance box
2) connection advice
How would people suggest connecting the PAMCO sensor to the E-Advance box wires? Options are either use butt-connectors and hardwire/heatshrink the wires to make them sealed OR plug each side into a 3 pin connector for future access. Any thoughts or preferences? I don't plan on modifying/changing this in the future - assuming everything is working okay.
3)Since I'm running the whole stock harness, the mounting area of reccomendation for the coil (to the frame with the plumbing clamps bewtween where the two stock coils were mounted) is extremely tight. Are people moving their horn, flashers, and the black rubberized box that sits just infront of the coils (self cancelling light unit?). I just see everything being *very* tight once done, and I just don't want the heat from the coil to cause any problems to other wires pushing up against or near it.
Thanks - looking forward to getting this wrapped up and back on the road.
1) Wiring
Harness:
Orange --> Cap off
Gray --> Cap off
Coil:
