dillon0990
So I started working on my build 1977 xs650 several years ago and then got busy with other things. I am full bore on it now and have the rolling chassis pretty much ready for the engine. I have the engine on a stand and ordered everything to replace the cam pushrod seal, bushing and upgrade to long rode in place of the dual rod. While waiting on that to arrive I pulled the side filter which appeared clean and then pulled the sump filter. GOOD NEWS....sump was intact and did not have much shavings. BAD NEWS---found several pieced of black plastic. Likely the cam guide.
My questions-- how much plastic is acceptable? I would say there were 10 pieces some up to an inch, but it was thin strips almost like the edges. The engine is out with both side covers off. I planned to replace clutch disks while in there. Engine has ~20,000 miles and has not ran in 10+ years. Engine turns over nice with spark plugs out. Before parking the thing had enough compression to throw you off the bike if you didnt kick it like you meant it. I have not done a compression test, but I assume the compression is still good based on kicking it a few times before taking covers off.
Should I go ahead and tear into it for the cam guide? It sucks because there is no leaks other than clutch pushrod seal and I think all internals are good to go.
If the answer is yes, my build just got extended. What do I NEED to buy to complete this? Do I need a full gasket kit if I am just doing the cam guide? Do bolts/nuts need replaced?
