Sigh, sigh sigh...
I tried to turn out the fuel mixture screws to clean the passageways as per the directions above. The left side screw was 3 turns from the bottom (I turned it down to the bottom and counted how many turns), the right side screw was 1.5 turns from the bottom. I loosened the left screw completely but couldn't easily extract it. I don't have a probe or sharp device to pull it out, besides a watchmaker's screwdriver. Since I didn't want to damage the o-ring, I took the easy way out and turned them both back in to the bottom, and then backed them both out by 1.5 turns, which is the amount stated in the carb guide (hope I'm reading it correctly)....So, no, I didn't clean out the fuel screw passageways...
Do I get a time out for taking the easy way out and not following directions to clean out that passageway? Is this what's preventing the bike from starting?
I battled for hours again to get the carb set to fit back onto the manifolds - I pushed, pulled, tilted, lubed, wiggled, cursed - nothing worked. When I would get one side in, the other side would pop out slightly either at the top or bottom. I took off the carbs and studied the whole picture carefully and then discovered something - the left side manifold is straight and the right side manifold is angled. If I stand on the right side of the bike (actually sit on a stool on the right) with the carbs off and look at the manifolds at eye level, the left side manifold is completely straight and at 90 degrees to the cylinder head. This means that the left side carb will go in straight. However, the top of the right side manifold slants towards the front of the bike, it's offset by a good number of degrees. It's clearly visible. No wonder I couldn't get the two sides to line up. So what I had to do was insert the carbs in a kind of a "middle of the ground" manner - they are both in, but not pushed in to the very end. As a result, the carb set is not sitting completely level now. Is this normal? I wonder what is causing this? The manifolds look good. I cannot see why it would have been built this way, angled, but maybe there is an explanation from the gurus on this forum??
So, I tried starting it again, and nothing. I smelt gas, but the puppy ain't firing up.
Where do I go from here fellas? Are you guys having fun yet?
