kvanderploeg
The Dutch Terror
5twins got ya answered. Now go put the timing light on it!
OK, em, you know the ignition is firing when it should. In your system, both plugs are fired at the same time, from the same coil. Now do what you should have done to start with: switch the plug caps from one side to the other and see if the problem changes sides. If it does, you have an ignition issue; probably bad plug, plug wire, or cap.
