Looks like I went too far with adjusting floats in order to not have the "rich-running at idle" condition. (just to re-cap, it was so rich that the right side cyl's plug would gas-foul and not run hardly at all, leaving that side "cold")
Adjusted plastic floats to 23mm.... thus hoping to have them positioned for leaner running. I also put in one size smaller than stock pilot jets. Also went through carbs again with carb spray, although I didn't do a full dis-assembly.
Put carbs back on and it just cranked and cranked and cranked and wouldn't start up at all, choke or no choke. Previously it had been rich enough to start from cold with no choke at all.
Had spark. Had at least some gas in bowls.
Finally I sprayed starter fluid into the carbs and it did start up, but just for a few seconds.
So, carbs will come back off tomorrow.
I guess it would be best to only do one thing at a time.
Thinking I can change the pilot jet with carbs still "in" bike but not stuck in intake boots. i.e. take them out of boots and with them loose, I can remove bowls, rubber plugs and swap the old pilots back in.
So at that point I will have LEFT the floats at 23, but gone back to stock pilot jet.
I'm really curious what that might do.
My guess is maybe it will start a little better but run real lean and I will have to mess with floats yet again.
So throughout this whole trip, it's gone from being able to start from cold with no choke and running super-rich, to not starting or running at all except WITH choke and with starter fluid sprayed in.
Just wondering how much difference one size on the pilot jet can make. hmmm
Back at it sometime this week, as time allows. If I have to take the carbs off and out again to do floats, I won't put them back on without doing the level test with tubing.
