put the carbs back on yesterday after having had them pulled and on the bench for several days, where they mostly just sat.
However I did re-set the float height to 23 mm. (plastic floats)
I'd been really encouraged by good compression readings several days ago, and thought oh well I guess the valves are ok and rings, since I did get the good readings.
So I put the carbs back on and, no joy.....still the same freakin' thing. Right side doesn't get hot and spews an oily gas mixture out the tailpipe and smokes white when revved. Doesn't make the smoke at idle.
So after I saw this was going to still be the case, I pulled the bowl of the right carb (bad side) with the carbs still on the bike. I then put a 2nd gasket in the bowl, thinking that would effectively lean that carb out more and be equivalent to having set the float that much higher even. But when I started it - same sh_t.
And really the left side is running rich, too. At one point I got highest idle with right mixture screw all the way in and left one almost all the way in, too.
I guess I could buy a pair of tiny pilot jets in, and try that. I think if any part of the pilot circuit could still be clogged it would be some part that has to do with air.
In the carb guide it says that the BS 38 type of pilot jets would "probably work" in the 34's. I have a bunch of BS38 pilot jets. I'm almost thinking of sticking a pair in there.
The numbers on pilot jets - do those refer to the amount of fuel they flow through their holes? or is does the numbering not refer to that?
I guess I will check valve adjustment yet again. Have done it twice. Cam chain tensioner adjustment is normal. Maybe I will leave the cap off the cam chain tensioner while the bike runs and try adjusting it a little while it's running.
I wish this could be simple. I'm getting fuel, spark and air and yet I have very little combustion on a right cyl which, however, has a decent compression reading.
Then I thought, well could it be the coil. Switched the plugs from side to side. Bad side remained bad side. Since it's an elec ignition bike and runs and charges, can I rule out timing issues? When an ignitor box goes bad, does it send "wrong" timing signals to the coil?
As I mentioned earlier in the thread, I'm using (for now) "clear" spark plug caps and can easily see that I have spark. The spark, as seen by my eyes, appears equal on both sides. It's not like it's intermittent on the bad side.
I'm trying to rule out certain things.
It comes down to fuel not being burned in right combustion chamber.
Maybe exhaust valve not opening?
sheesh.......
Do the fairly decent compression readings rule out bad valves?
Anyway, tomorrow, the carbs will come off again. Not sure what else to try, except go through pilot circuit yet again. Check the 3 tiny holes in throat of carbs....
Sure wish I had a known good pair of carbs on hand.
I lost the battle to a pair of carbs once before, when I had my 79. I just could not get one side to run right. At the time I gave those away, I would have sworn up and down they had some kind of crack or defect in the castings.
As soon as I put the carbs which had been in THIS bike on it, it ran perfectly. I then bought this set of carbs and saved them for when I got around to this bike again.
So now I'm faced with very nearly the same issue - a very rich running right side. On those 38's, I even replaced all the parts in the choke, too, thinking maybe the choke wasn't ever closing completely off. Still had the prob.
I'm really trying to think this through with my brain and the basic rules I understand about simple engines.
This has me pretty frustrated.
On the bright side though, the battery I'd thought dead works great now. Cranks and cranks!
And the bike runs and runs! just not on the right side cylinder.
