Update time again:
I had the front half of the frame sandblasted for $4 dollars. I know, it's crazy, but I drove an hour with the frame in the trunk of my Stang just to get it done. And this was the evening before my 9am welding appointment. Lucked out there... The guy was already blasting some farm equip and he simply took about 6 minutes to blast my lil old motorbike frame
We stuffed a rag thru the steering neck, and this is how it helped, what do you guys think?
And........WELDING TIME!
And as soon as I got it home, I just HAD to throw as many parts as I could onto it just to see
Now that was 5 days ago. Between then and now I've done a little more work on some things, including painting the wheels, and fabricating my mid-control mounts out of the stock cast peg assembly. Over at XS650chopper there is a thread about how to do this mod, and I kinda loved the idea, and the pieces were just laying there, so what the hell! Heres a few shots of the steps I took:
I also decided to clean up the triple clamps, so I did just that. I started on the lower one, and ground off everything but the 'stops' for the steering movement. Here's a few more shots. These are grinder with 1/8th inch cutoff wheel, followed by flapper discs (80 grit) and followed by a random orbital hand sander.
Next came the carb cleaning and rebuild. I used an ultrasonic pulsing parts cleaning machine. (Operates somewhat like a microwave, and boils water ONLY at the surface of the objects submerged in it. So every little orifice that's underwater is boiling at the surface) Then rebuilt as stock:
Then came the painting of the wheels, front wheel first, followed by front rotor, then rear brake drum and wheel:
There was a slight dimensional problem with using the ammo-can I originally wanted to use and interference with the chain. It just wouldn't work without cutting holes in the box, which I didn't want to do very bad. So digging around the shop and I find an old fire-extinguisher to use as an oil-can, but rather than paint it with the bike, I'm going to modify it to look EXACTLY like a nitrous bottle. Bright blue paint, and orange and white labels.
I will have what little wiring is on the bike inside of it, and the bundle that comes out will be thru one of those AN fittings (blue and red anodized) with a 90* elbow and covered in stainless braided line so it honestly looks like I have N
20 plumbed into my engine, lol!
And last but not least are some updated overall shots, and this is the stance I want when it's all said and done.
Stay tuned for the next action packed thriller in this epic journey through cheap-bobber-building!
Logan
