Bob Kelly III
Ranch Kid from way back,.... that got Old !
that was well handled Weekendrider ! I think I would have taken offence ! ...that just shows I need more work ! LOL
Bob........
Bob........
what is the part I put in the picture.I see no purpose,perhaps it used to connect to a stock airbox.Yes lots of dirt and grime.That is removeable. My clymers has sweat and tears on it,no blood so far.I remember over 10 years ago i had never touched a motorcycle engine in my life.My 1980 gs 1000 blew a head gasket.Actually it was a small little rubber oilseal under the head but it required tearing the motor down to the block.I also took the block off and replaced the cylinder base gasket.Getting a cylinder block down over 4 sets of pistons is not easy by myself.I did not know how to hone cylinders,i think thats overrated anyway.There are about 4 different things to line up to get one of those in time.I had the carbs off at least 10 times, the head back off at least 4 times.i did this all with the motor still in the frame.But the first time I rode it what a satisfying feeling.This motor does not appear to be as complex.I sure hope not.Yeah clymers isn't complete, does not have section on grime and grit. I think I see both in the pic.
A clymers is only really useful if it is used, torn, has grease soaked areas and evidence of having been used to level out the ground under hte center stand. But yours is probably looking like that by now.
Bob........
not sure why you sent me this.general forum rules?....and WeekEndRider is actually a very knowledgeable guy and has been a great contributor of useful and friendly advice to many of us....
If I may say: among the hallmarks of this wacky group are:
- we often kid around but we don't (usually) take things personally;
- any poking should be assumed to be all in fun - and a good way to be sure is to use the smileys to be certain that your message is not misinterpreted;
- if you think that you might have offended anyone - send them a PM and apologise. It costs nothing and shows class;
- if you think you may have been offended by someone - put your big-boy pants on and forget it;
- advice is freely given and is generally totally reliable - but should be accepted as being without warranty on a strictly as-is/where-is basis;
- if it's on YOUR bike and YOU were turning the wrench - and it breaks - it is YOUR fault.
....now back to our regularly scheduled program.
weekendrider is the one i poked fun at so far plus mr 2 wheels.I have ridden since 1972 and have read many posts from members and i know when a knowledgeable guy posts.Those are the ones I pick on for fun.I want to not joke around but i cant help myself.....and WeekEndRider is actually a very knowledgeable guy and has been a great contributor of useful and friendly advice to many of us....
Re. the starter solenoid: it's a low load switch that closes a high load switch. The contacts for the low load switch are as described: Red/White hot wire, Blue/White switched ground wire. When the low load switch is closed it closes a connection between the two posts. One post should be connected directly to the battery + terminal by a thick cable. The other post should be connected to the starter motor by another heavy cable. Both are hot--if you ground one post you'll just blow a fuse when you hit the starter button. The starter motor is grounded to the engine.
I have no better idea than you of what the PO was up to. The only thing I know how to do in a situation like that is to meter out the mess.
true that.I destroyed a gs850,melted the harness by connecting something wrong.I bought a replacement off ebay.once in my hand I thought brilliant, now you have another one to destroy.I sold it to a former harley mechanic.As he was paying me he looked at the wiring and smiled.I bet he had it running in one day.I sympathize, having been an acute electrophobe for years. According to the APA, the only known cure for electrophobia is a mixture of study, observation, stubbornness, and high tolerance for humiliation.
I need to get a fusebox like someone suggested with spade connectors.It would need one spot for main,taillights,turn signals,headlights,brakelights? Just guessing. But then,how to wire it in.Over my head.I am going to get rid of 10 pounds of dirt from it soon.I work night shift, working next 2 nights.After that i am rolling it outside and take a bucket of carwash and get it at least cleaner. Looking at schematics sometimes they show a square with fuses in it.I work in intensive care unit.Have for 32 years.If I took a layperson into a room, and said this is an arterial line, this is a pulmonary artery catheter, this is a left ventricular assist device, these 4 ivs have 3 vasopressors and one calcium channel blocker because of runs of paroxysmal atrial tachycardia would you know what I mean? Thats how wiring is to me.Every post someone knowledgeable like you send my way is clearing the fog.Ron : You need a battery and Volt Ohm meter or trouble-light and install the battery and hook up the ground from the neg side of the battery to a bolt on the frame. ( a heavy wire or cable should be used)
if the fuse box is missing it's going to be a long hard haul getting that thing working again.... You have to do it, no one else will, so put on you thinking cap ! sounds like your not Incompetent ! so Go for it ! Reason and electric circuits do actually work.... but it's variable at times , or at least seams so !
.....hehehehhe !
Personally I like allot of Posts, it shows that your interested, check often and are still pursuing the task !
in the Tech section here there is a bunch of easy to read Wiring diagrams , the Identification number is stamped under the front Right frame engine mount, on the engine it self , it's hard to see but it can be done . matching that number with the list in the tech section will tell you what year and all the bike originally was .
the tech section can be found here under forums, Garage..... then select tech section at the top.
Joking around is done here ! quite a bit ... and yes the smilies do help ! LOL....
A motorcycle is a Learning experience.... all the way through , you learn how to make the money to get one in the first place , then you learn how to make it run, then you learn how to ride it without Killing yourself ! <GRIN>
clean that poor machine up man ! it's Killing me seeing is all dusty like that !!!!! LOL
....Bob.......
