ron bayless
My bike has 30 years of crud on it.Eventually i will pull the motor and do a proper cleanup.I have many things to do first like get it running.Do the carbs come off before it can be pulled.I have much carb cleaner. Are carb kits mostly a gasket and cleaning it right.I never stray from stock jets.I have ordered a manual.Are the carbs supposed to have some sort of airbox with filters attached to them? Does the bike have one throttle and choke cable and the carbs linked with a rodtype linkage? Some of this will be answered when i get the motor out.How hard is it to get out? The online manual says to remove the clutch,case covers and other things that seem unneccessary.
I will replace the swingarm bushings,steering head bearings while the motor is out. the 2 exhaust gaskets should be fairly generic.I do not have the right equipment to polish the cases but do want to.Very tedious at best.
My chain was removed before i got the bike.I still do not know what kind of warning about the motor that might be.The left casecover is loose,so they could slip it off the sprocket.From that point to get it off the bike the rear wheel would have to be pulled.I still think it would be looped around the swingarm. But a nonmasterlink chain would have to be removeable without breaking it. MIKES XS seems to have everything.I have heard good and bad about the company.Is there another place you all use?Thanks for any input.
