'83 Special.
Reworked some used mac headers. Got the cheapo flanges off and replaced with the stock ones off a pair of junk pipes. Cut the stock inserts off where the 2 pipes , inner and outer, attach. Worked the ring, where the mac flanges connect to the header, off. Re-assembly was 1 exhaust gasket, stock insert, header and buttoned down with the stock flange. Using an aftermarket set of emgo mufflers for now. Thinking of cutting the forward (engine side) end of the baffles off, would like to get a lower rumble. Anyone ever played around with the emgo baffles?
