XSNate
If I put a vr115 regulator is it necessary to replace the rectifier? My experience is that a rectifier either works or it doesn't , agree?
so could a slighlty higher amp cause the reg/rect to get a bad reading n send a low voltage to the rotor?? im only getting 10v from reg/rect to rotor... i replaced grounds and connections thinking maybe bad connection/ground causing reg/rect to get a bad reading n send a low volt to rotor but no change..popped in a new reg/rect just to find right out the box its still sending only 10v to the rotor..im starting to think having switched to a gel pack battery that maybe for some reason its too strong n allowing too much amp to the reg/rect?? checked the fuse for the power to reg and it was fine but was on the bit too hot side but not kicked..was thinking maybe bad fuse just isnt kicking allowing too much to the reg/rect so its doing its job n sending less volts??
RG, can you elaborate on this "voltage drop" thing with the rectifier? Is it something I can test my rectifier for? I have the replacement made up, just not installed yet. Have the VR115 ready to go as well but same deal, just not installed yet. The bike charges fine still with the original components but I'd hate to be putting undo stress on my rotor.
What's the story on the nylon washers? I have a 79. Do I need to change?
I see it says 80-84 so I think I am ok. Must be something different in the circuit?
went thru all the connections, replaced the fuse, ran a new ground and she seems to be hitting the mark. im still going to keep an eye on it the next few days due to the fact i had it seem fine a few time to only have a dead battery days latter..and of course suttin lil n stupid had to happen on my victory ride..flippin gas cap popped off and despite two passes of looking for it no luck but tomorrow ill look again when its light out. thank you all for your help
