So I want to remove the bushings preferably without destroying them, anyone done it? How?
quick lazy search didn't turn up any how to's.
Some guru should make me a video and post a link here so I can watch it on my phone..........
Gentlemen
this is a weird solution but it worked very well . just now.
I tried with a long brass drift but could not find any edge to hit on
So I went to my new socket set ( toolbox ) and tested 1/4 inch socket for a fit inside the cam.
I found that 1/4 inch and 5/16 was almost the same diameter . As the cam.Inner diameter.
But still no edge inside that would take up the force.
the 1/4 inch socket has a taper / fillet on the outside up to the diameter that is close to the cams inner diameter.
I took a soft steel wire .1.45 mm
Not sure what that is in Inch
And made a circle about a 3/4 circle
and wound it around the socket the smaller end .Inserted it into the cam
Some soft tapping with the hammer - And the steel wire landed in the Recess / Grove inside the
labyrinth seal .. But now sticking out a bit so now the Socket would not fall past the
Wire. Like a circlip
Socket in --and use the brass drift .. And after a couple of taps Out it came
I had it in an upright position standing on another larger socket when i Did it .So it could fall out freely.
The other side ( labyrinth ) did not succeed that well with the taper and socket
So more use with a needle nose pliers.But fairly simple that also.
I have not cleaned them yet but I can not see any damage on Them.
I will use a Boyer ignition so it is good enough for me.
