brianmac
I just got a 1982 Xs XS Heritage special spoke wheel single front brake appears to only have 4000 semi miles on it oil is clean . PO said he had it for 10 years started up once in awhile the inside of the tank is clean it has Mikuni 36vm carburetors with a 190 jet main jet I clean the green and yellow out of the carbs but I need to soak the jets in vinegar it has a brand new battery Deka AGM it charges up to 14 volts . It shakes so bad it will run across my garage floor the right side was too lean and Poppin iItweaked that out . so now
I'm cleaning the carburetor Jets with vinegar and and c check float level 18 mm please advise if possible
