It hasn't failed. The stator apears ready to fail. The windings are burned and I can feel them moving around when I touch them with my finger. All of this was installed a month or so ago, so I assume it to be under warranty from Hugh's Handbuilt. Awaiting a reply from the man himself. The thing I'm worried about is putting a replacement on that also fails, potentially when I'm in the middle of the Mohave desert. If there's something I can do to prevent that...
after reading it sounds like I'm using about 60 of the available 200 watts. My shunt (shit?) regulator is supposed to convert the other 140 watts to heat. If it doesn't do that, two things may happen.
1) too much voltage will go forward to my components, and fry them. For me this really only is my PAMCO (which is still fine). I'm not too worried about blowing a light bulb, they can handle a wide range of voltage.
2) too much voltage will go back into the stator, causing it to get so hot the sticker and paint literally burns off my rotor, and then the stator burns out.
So, it sounds to me like I either got a bad stator that was destined to die or my regulator was not doing its job, shits were about to hit the fan, and maybe I caught it in the nick of time.
From what I can tell, this cannot be the result of a bad cap. Right? It's job is to smooth out the electrical pulses, my problem is from over voltage.
Thanks!
Adam
ps Please please please don't waste the time of people who came to this thread because the have a similar issue and want to find the solution by talking shit about how I'm a dumb fuck for buying a PMA. Thanks.
You may have simply bought a defective PMA or regulator. Factory defects do happen. When HHB supplies you with a new alternator and regulator, that should be the end of the problem.
I've said this a few times in the past, but its worth while saying it again. We're all driving around on 31+ year old bikes. If you plan on taking long trips into the desert, (or the mountains as I do) a wise biker would install an onboard voltmeter. The voltmeter will give you advance notice of electrical under charging/over charging problems, before you strand yourself, and die of thirst under a thorny cactus.
Once you have a voltmeter on the bike, you can put on some local around town miles, to secure your belief that you have a reliable alternator/regulator, before you hit the road.
Edit: Another simple mod is to space the alternator cover out from the engine case, to allow for some cooling air in and some hot air out.
