sounds like a carb if its not spark.I had the same problem too. Do you have the stock BS34s? The pilot circuit fuels the engine in low-speed operation, when the slide is lowered. In the back of the BS34 (80-83) you will find four round holes
The upper pair (below curved diaphragm chamber vent) vent the carb body above the
floats. Below those are the air jets. The pilot air jet is removable, and the main air jet is
fixed. In BS34 carbs the pilot jet is under a rubber plug at the end of the smaller vertical tubular casting in the carburetor body; the plug must seal correctly. Use a screwdriver or bit that completely fills the slot of the jet. If the jet
area is fairly clean and uncorroded, one sharp push-and-twist should free the jet. If jets
are fuel varnished, prep them for removal with solvent. In the BS34, spray-in solvent can be applied to the jet area and followed by compressed air until varnish breaks up--never immerse
carb bodies. Apply a bit of penetrating oil and allow it to soak in. Then seat the
workpiece firmly in a padded vise or clamp, and remove the jet. Use a sharp push-and
twist motion to break the jet loose. Light taps on the screwdriver will often break a
stubborn jet free. If the slot deforms, use a screwdriver with a thicker blade or regrind
the one you're using. Once the jets are removed, check to see that the correct series is in place. "
Now this is where my problem was the oring was bad and it flooded the cylender out" The fuel screw in the BS34 carburetor is recessed in a vertical tubular casting on the
carb body toward the center line of each carb, forward of the slide tower. Unless it has been removed, the screw is covered with a thin brass cap, which
must be removed for cleaning and adjustment. Pierce the cap with a drill, being careful
not to damage the casting or the screw; just penetrate the cap. Sometimes a sheet
metal screw will hold firmly enough to grip the cap while pliers are used to extract it
(don't run the screw in deeply; avoid damage to the mixture screw beneath). Sometimes
it can be pried out after drilling. Remove the mixture screw, with the spring. A rubber Oring
is at the bottom of the mixture screw seat, with a metal washer on top of it. Remove
these with a probe. When new, the washer is somewhat flattened; this does not indicate
defect. Be sure that it's flexible and has no nicks or cracks.
If fuel screws show signs of damage, wear or corrosion pits, replace them.
CV Carbs - one of the best how-to manuals ive found for the original carbs
http://www.amckayltd.com/carbguide.pdf
you can download a keep on you computer the info that Igave you came from the carb guide, good luck
