Hah, there's
lots more room than I thought. Especially if you measure from the fuel inlet lower down and NOT the overflow. #brainfart
But I'm not going to use the inline fuel filter I have. I bought it a while ago and stored it away. Now that I've got my "bottom drawer" of bits and bobs I find I've been a bit hasty. its 6mm and it needs to be 8mm. I've decided to get one of those Kawasaki fuel strainers in the EX500 post. I wish I'd read it ALL before starting.
You guys are lucky in some respects as little bits and bobs like that seem more easily available and even a bit cheaper over there. Here I can buy something for "a fiver" and postage and packing costs the same. #modernlifeproblems
Brake line was specced on line and bought from
http://www.helperformance.com/custom-brake-hose. Brakes all assembled and fitted but needs fluid and bleeding.
Battery charged and fitted and surprisingly, although its not "all systems go" I have a decent spark and the indicators and warning lights including neutral indicator work. Headlight doesn't work for some reason.
Tank has been drained of old petrol, flushed out a bit. Inside looks fine. Fuel pipe all connected up and a little bit of fresh petrol run through from each side into a paper cup just see if anything nasty comes out. Fuel flows fine and clear.
Getting real exited now but needn't be. As soon as I turn the taps on fuel poured out from the pod filters. So I'm going to have to get into these carbs. They "came off a running bike". But that's a bit like "the cheques in the post". I've noticed a malformed head on the choke assembly as if the bike had fallen and also the tick over adjuster was bent and needs straightening. The two fuel drain screws are different. One has a cross-head and the other a cross head which looks like its had a slot hacksawed over the cross head. They work fine though.
A little later I realised that the right hand tap was leaking a little.
So I'm ordering a Kawasaki fuel "strainer" and a couple of rubber tap grommet/washers. FML they are £10 EACH + postage and packing. It would be gross stupidity just replace one. Oh, and some clear pipe and some other bits and bobs.
Still, when you've a petrol-soaked rag in you hand wiping some 40 year old muck off stuff seems like the right thing to do.
So I'm stalled but not stopped. I'd much rather have some problem that I know how to approach than a bike that just won't start or a charging system problem.
BTW - In case anyone is wondering, no I've not been inside the carbs yet and I do realise the jets and needles will need changing. But someone's posts online said that their bike ran after a straight swap and I'm now keen to get it making a noise of any sort.
