mynameissean
I just got a tail light and the only wires that it has coming out of it is red and black .. I have no idea wat ti do so it will work and will light up when I hit the breaks
If you have an alloy rear fender with the tail light on that, I think you're going to need to send an earth from the light to the frame.
If steel okay
is there a way to have just the tail light and it get brighter when brake is applied?
This is a real shot in the dark here, but does anyone happen to have a simplified wiring diagram for a 79 2F that's got headlight, tail light, turn signals, no starter (kick only), pamco ignition and everything else stock?
Dave
Yes, they are usually grounded at the mounting bracket, but if they have a black wire (or ground wire) then ground them.Also, I have to ground the blinkers yes?
Just swap out the Cap for a Battery. Works the same way.ALSO interested in the BATTERY install.
How would I modify it if I'm not going to use the PMA and capacitor? I imagine I can use the stock charging system in the same place as the PMA, yes? And would I put the battery in place of the capacitor as is?
